C45E / C45R / Cf45 Steel
Steel name: C45E / C45R / Cf45
Diagram No.: 795
DIN designation: C45E, C45R, Cf45
Mat.No. (Wr.Nr.) designation: 1.1191, 1.1201, 1.1193
Chemical composition in weight %:
C45E: 0.42-0.50% C, <0.40% Si, 0.50-0.80% Mn, <0.035% P, <0.035% S, <0.40% Cr, <0.10% Mo,
<0.40% Ni, Cr+Mo+Ni=<0.63
C45R: 0.42-0.50% C, <0.40% Si, 0.50-0.80% Mn, <0.035% P, 0.020-0.040% S, <0.40% Cr, <0.10% Mo,
Cf45: 0.43-0.49% C, 0.15-0.35% Si, 0.50-0.80% Mn, <0.025% P, <0.035% S, <0.40% Cr
Steel group: Structural steels
Comment: The legend: Harte in HRC - Hardness in HRC, Abstand von der abgeschrechten Stirnflache in mm - Distance from quenched end in mm.
Hardening: 820860oC/water, oil
CCT & TTT Diagrams of Steels
Etchants Database
Disclaimer: The information and data presented herein are typical or average values and are not a guarantee of maximum or minimum values. Applications specifically suggested for material described herein are made solely for the purpose of illustration to enable the reader to make his own evaluation and are not intended as warranties, either express or implied, of fitness for these or other purposes. There is no representation that the recipient of this literature will receive updated editions as the become available.
Copyright © 2017 by Steel Data. All Rights Reserved.
