1.6773 Steel
Steel name: 1.6773
Diagram No.: 817
DIN designation: 36NiCrMo16
Mat.No. (Wr.Nr.) designation: 1.6773
Chemical composition in weight %: 0.35% C, <0.40% Si, 0.45% Mn, 1.80% Cr, 0.35% Mo, 3.85% Ni
Steel group: Structural steels
Applications: Structural steel of a broad application range for wear resistant components, exposed to
high permanent stress. Due to good hardenability, this steel grade is suitable for lager cross sections,
too. It can be used for tools (e.g., cutters) with a hardness of 45-50 HRC.
Comment: No data
Hardening: 835-865, 855-885oC/oil
CCT & TTT Diagrams of Steels
Etchants Database
Disclaimer: The information and data presented herein are typical or average values and are not a guarantee of maximum or minimum values. Applications specifically suggested for material described herein are made solely for the purpose of illustration to enable the reader to make his own evaluation and are not intended as warranties, either express or implied, of fitness for these or other purposes. There is no representation that the recipient of this literature will receive updated editions as the become available.
Copyright © 2017 by Steel Data. All Rights Reserved.
